This lesson covers distortion parameters of ADC. It discusses the effect of phase jitter at the output and provides an example of calculating the jitter in seconds for a dynamic range equivalent to the quantization noise from a 12-bit system. The lesson also explains the Signal-to-Noise Ratio (SNR) due to jitter and quantization noise, and how to calculate it. It further delves into the impact of different types of noise on the Analog-to-Digital Converter (ADC), including phase noise, jitter, and spurs. The lesson concludes with a discussion on how to calculate the noise level for any signal level and the overall system level noise.
00:18 - Phase jitter effect example
08:58 - Explanation of the impact of spurs in the clock on the frequency domain
12:45 - Noise of ADC on overall system level noise
23:47 - Noise calculation
26:05 - Effective noise figure of ADC
- Phase jitter at the output can affect the dynamic range of a system.
- The Signal-to-Noise Ratio (SNR) can be calculated using specific formulas for jitter and quantization noise.
- Different types of noise, including phase noise, jitter, and spurs, can impact the performance of an Analog-to-Digital Converter (ADC).
- The noise level for any signal level can be calculated using a specific formula.
- The overall system level noise can be calculated by considering the noise contributions from all components, including the ADC.
