0 of 12 Questions completed
Questions:
Quiz is loading...
0 of 12 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is the difference between steady and unsteady flows?
What is fluid statics?
What are the properties of Newtonian fluids?
What are the characteristics of turbulent flows?
What are the two main approaches to describing fluid motion?
What does the continuity equation represent in fluid dynamics?
What is the substantial derivative used for in fluid kinematics?
What are the properties of the angular velocity tensor and the shear strain rate tensor?
What are the characteristics of the Lagrangian approach in fluid kinematics?
What is the starting point for deriving the Navier-Stokes equation?
What are the two types of forces acting on a fluid element?
How many components does the shear stress have in three-dimensional fluid flows?
