0 of 10 Questions completed
Questions:
Quiz is loading...
0 of 10 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is the key performance metric that determines the size of the equipment in a power cycle?
What is exergy destruction?
What are the characteristics of open feed water heating? (Select the two correct answers)
What is the purpose of reheating steam in a Rankine cycle?
What is the process of the Brayton cycle?
What is the effect of pressure ratio on the cycle?
What is entropy crucial for? (Select the two correct answers)
What happens to the specific power when intercooling and reheat are added to the Brayton cycle?
What happens to the thermal efficiency when intercooling and reheat are added to the Brayton cycle?
What is the key performance metric for the heat exchanger in the Brayton cycle with regeneration?
