0 of 6 Questions completed
Questions:
Quiz is loading...
0 of 6 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is the conventional route for preparing metal matrix composite?
What is the role of mechanical mixing in the preparation of composite material?
What elements are used to reinforce the matrixes?
Which materials are prominently used for making composites?
What role do laser parameters play in additive manufacturing?
What happens if the reinforcing agent has a high decomposition temperature?
