How to perform a spring-back analysis in Explicit Dynamics?
Spring back refers to geometric change towards original shape that occurs in a structure during the manufacturing processes when the forces are removed. Evaluating this phenomenon while designing a structure can be crucial for its working and application. Refer to the accompanying solution file to explore the spring back effect in a sheet metal forming process.
You can access the relevant file here – Download Files
For additional details, you may want to refer to the document below –
