This lesson covers the design and analysis of axial flow turbines. It delves into the three-dimensionality of flow through these turbines, highlighting the non-uniformity of flow through the annulus space available to the turbines. The lesson also discusses the importance of factoring in variations from the lower radius to the outer radius, or from the root to the tip of the blade of a rotor, in the design and subsequent computations. It further explores different design theories that factor in the three-dimensionality of the flow and how they are used in the design and post-design analysis of turbines. The lesson concludes with a discussion on solving problems related to three-dimensional flow in axial flow turbines, using the theories discussed.
04:42 - Explanation of the problem statement for the design of an axial flow turbine and how to find a solution to it.
10:40 - Discussion on the results of the problem statement for the design of an axial flow turbine.
14:42 - Explanation of the problem statement for the design of an axial flow turbine with three different design methods and how to find a solution to it.
23:45 - Discussion on the results of the problem statement for the design of an axial flow turbine with three different design methods.
37:37 - Explanation of the exercise problems for the design of axial flow turbines.
- Axial flow turbines have a three-dimensional flow that is often non-uniform.
- Variations from the lower radius to the outer radius, or from the root to the tip of the blade of a rotor, need to be factored into the design and subsequent computations.
- Different design theories factor in the three-dimensionality of the flow and are used in the design and post-design analysis of turbines.
- Solving problems related to three-dimensional flow in axial flow turbines helps in understanding the application of these theories to actual problems.
