How to obtain field quantities from a parametric sweep in Maxwell?
This document demonstrates how to save the fields quantities during the parametric analysis, and how to display the field values. As Parametric analysis offers the possibility to sweep variables values and run a set of different simulations, field result could be saved in setup and plotted in post processing.
Solution Document:
