0 of 5 Questions completed
Questions:
Quiz is loading...
0 of 5 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is a significant advantage of wire additive manufacturing?
What are some limitations of wire additive manufacturing? (Select the best two options)
Which path planning strategy is suitable for thin-walled structures in additive manufacturing?
What is one common defect in additive manufacturing?
What approach is used to understand the residual stress and distortion level in additive manufacturing structures?
