0 of 10 Questions completed
Questions:
Quiz is loading...
0 of 10 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What are the factors that influence the fractional flow function? (Select the 2 correct answers)
What is directly proportional to the rate at which each saturation packet travels?
What does the Buckley-Leverett formulation involve? (Select the 2 correct answers)
What is the relative permeability of a phase in a porous medium?
What are the two types of phases in a porous medium? (Select the 2 correct answers)
What is the significance of saturation at the outlet?
What is the formation volume factor used for in reservoir modelling?
What factors does the formation volume factor depend on? (Select the 2 correct answers)
What is used to simplify phase equilibrium in a three-phase flow through porous media?
What changes over time due to the flow of oil, water, and gas in a three-phase flow through porous media?
