This lesson covers the techniques used to measure flow parameters in chaotic flows, focusing on the constant temperature hot wire anemometer and the Laser Doppler Anemometry (LDA). The lesson explains how these techniques are used to measure flow parameters in a chaotic flow environment, particularly in turbulent flows. It also discusses the challenges of measuring turbulent flow parameters and the use of optics in flow measurement. The lesson further explains the use of hot wire anemometry and LDA in measuring fluctuating components of velocity in turbulent flows. For instance, the hot wire anemometer is used to measure the fluctuating components of velocity, while the LDA uses light to visualize the flow field and measure flow parameters.
01:04 - Constant temperature hot wire anemometer and LDA
03:10 - Turbulent flow and its characteristics
09:56 - Hot wire anemometry
29:57 - Use of optics in flow measurement
40:47 - Laser Doppler Anemometry
- The constant temperature hot wire anemometer and the Laser Doppler Anemometry are crucial techniques for measuring flow parameters in chaotic flows.
- Turbulent flow, characterized by its randomness and erratic velocity components, presents challenges in flow parameter measurement.
- The hot wire anemometer measures the fluctuating components of velocity in turbulent flows.
- The Laser Doppler Anemometry uses light to visualize the flow field and measure flow parameters, offering both qualitative and quantitative estimates.
- Despite the challenges, these techniques provide valuable tools for understanding and analyzing turbulent flows.
