0 of 7 Questions completed
Questions:
Quiz is loading...
0 of 7 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is armature reaction in electrical machines?
What influences the design of the compensating winding in electrical machines?
What is the role of Interpol thin poles in electrical machines?
What happens when a DC machine is loaded?
Why are load characteristics important?
Which of the following are types of windings in a machine? (Select the 3 correct answers)
In which direction should a brush shift be given in the generator mode?
