0 of 7 Questions completed
Questions:
Quiz is loading...
0 of 7 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is the primary function of a transformer?
What determines the level of flux in an AC magnetic circuit?
What factors can affect the current drawn by a coil? (Select the 3 correct answers)
In an ideal transformer, the magnetizing current needed to establish the flux is:
What are the characteristics of an ideal transformer? (Select the 3 correct answers)
What is the role of the number of turns ratio in a transformer?
What remains the same on both sides of the transformer?
