How do you set a particular font style or size in the graphics windows? How do you reduce the number of color range labels associated with contour plots?
As a general note, there is no single global setting that will affect all parts of the graphics window. Each part (captions, color range scale, and text annotations) can be controlled separately. Here are several useful commands for control of these entities. Type the commands in the cortex window as is, i.e., including parentheses, then redisplay the graphics to see the effects.
To set font size in the Captions area, type: (cxsetvar 'frame/title/font (format #f "size=0.2wru"))
0.2 is default. Modify the number as needed.
To change the font type of the Captions to Roman, for example, type: (cxsetvar 'frame/title/font "name=roman")
Tip: The "Annotate" panel can be used to determine what font types are available.
To set the font style in the Color Range area, type: (cxsetvar 'scale/font "name=roman")
To set the skip value for the color range label, type: (cxsetvar 'scale/skip-override 2)
0 — will calculate the skip based on font size
1 — will show every label
2 — will show every other label
3 — every third label, and so on
To change font in the text annotation area, use the Annotate panel (to open, click on Display > Annotate).
