0 of 7 Questions completed
Questions:
Quiz is loading...
0 of 7 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is the center of mass?
What are the additional degrees of freedom that a rigid body has? (Select all that apply)
What is the purpose of a free body diagram?
What is the importance of taking moments about the center of mass when applying Euler's second law?
What happens if the friction coefficient is less than the critical value?
Which of the following forces act on a sphere rolling down an inclined plane? (Select all that apply)
What does the no-slip condition imply?
