Sensitivity Analysis for Parametric Variation Analysis — Lesson 5
A Sensitivity Analysis increases the design understanding.
In this lesson, you will learn how easy it is to set up a Sensitivity Analysis since a wizard guides you through the steps. In the example the Adaptive Metamodel of Optimal Prognosis (AMOP) will be applied. Based on this approach dependencies between the Parameters and Responses can be examined and quantified.
optiSLang comes with powerful and interactive postprocessing with predefined visualizations for specific data evaluation. With this, the areas of interest for the optimization can be selected and investigated in detail.
Lecture
Alternate video link.
Video Highlights
00:09 – Start using sensitivity wizard
00:31 – Define the sampling method
00:55 – Adapt AMOP settings
01:17 – Additional solver options
01:42 – Sensitivity study postprocessing
02:01 – Quantification of parameter influence
03:21 – Interactive postprocessing
04:05 – Display signals
05:03 – Summary (audio only)
