Are there any tips for converging V2F turbulence model?
When the V2F turbulence model is turned on, sometimes it is difficult to get the solution converged.
Sometimes the residuals of k and v do not decrease, even though other residuals decrease very well.
1. Run the case with standard k-e model or RNG k-e model and get a converged solution.
2. Switch to V2F model via the TUI command:
(allow-V2F-model)
3. Define a custom field function 2/3 *k, where k is the kinetic energy. See Section 14.20.1 in the Ansys Fluent User's Guide for information about other custom field functions for turbulence.
4. Patch the values of V2 in the entire fluid zone from the custom field function created in previous step.
5. In the Solution Controls panel, make sure that the Velocity Variance Scale and the Elliptic Relaxation Function have the same Discretization schemes as the Turbulence Kinetic Energy and Turbulence Dissipation Rate.
6. Continue the iteration.
