0 of 10 Questions completed
Questions:
Quiz is loading...
0 of 10 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is the full form of HFSS?
What is the minimum frequency that will propagate through an air-filed rectangular waveguide, if the larger dimension of the waveguide cross section is 1.5 cm?
What is the cutoff frequency of TE_{10} mode for the WR-15 waveguide as per Electronic Industry Alliance (EIA) standard?
Which of the following command is used to create a twist from rectangular waveguide cross section in Ansys HFSS?
Which of the following command is used to create a H bend from rectangular waveguide cross section in Ansys HFSS?
Which of the following is correct regarding the creation of variable in Ansys HFSS?
Which of the following is correct regarding accessing the variables in Ansys HFSS? (Select all the correct options)
Which of the following is correct regarding the parametrization of variables in the Ansys HFSS?
Which of the following is one of the ways to create the waveguide E-bend from a rectangular sheet in Ansys HFSS?
