Download the zip file and extract the contents. Go through the Instructions file. Follow along with the provided steps and solve the model. You can start the quiz after you have obtained a solution.
For performing the simulation, you can use the latest release of the academic, commercial or free student version of Ansys Mechanical. Download Ansys Student for free here.
0 of 10 Questions completed
Questions:
Quiz is loading...
0 of 10 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
For the present case, what is the maximum total deformation obtained under the given load? Select the option that is closest to the correct result.
What is the maximum equivalent (von-Mises) stress value obtained in the present analysis? Select the option that is closest to the correct result.
What is the dominant direction of reaction forces developed in the hole C? Select the best option.
To replicate the same constraints in Hole C, which of the following boundary conditions/connections can be used? Select the best option.
What is the minimum safety factor against tensile yield strength of the model using the Max Equivalent Stress theory? Select the option that is close to your answer.
Which of the following statement is TRUE regarding the reaction moments formed in the hole D? Select the option that is closest to the correct result.
In the below figure, what kind of stresses are developed in the locations P and Q? Select the best option.
How much percentage of the total force is developed as reaction forces in hole C? Select the option that is close to your answer.
Statement-I: All of the reaction forces are developed in only Hole A and Hole C.
Statement-II: No reaction forces are developed in Hole D since there are no constraints for the translational movement.
In which direction do we have maximum deformation and why is that? Select the best option.
