Download the zip file and extract the contents. Go through the Instructions file. Follow along with the provided steps and solve the model. You can start the quiz after you have obtained a solution.
For performing the simulation, you can use the latest release of the academic, commercial, or free student version of Ansys Mechanical. The free Student version of Ansys simulation software is available here.
0 of 10 Questions completed
Questions:
Quiz is loading...
0 of 10 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
What is the maximum Total Deformation of the pipe for System A (Contact)? Select the option closest to the correct result.
What is the maximum Equivalent Stress of the pipe for System B (Shared Topology)? Select the option closest to the correct result.
To obtain a conformal mesh at the interface of the flange and pipe, which method should be used? Select the best option.
Compare the maximum Total Deformation of System A (Contact) and System B (Shared Topology). Select the best option below that is closest to the correct result.
By default, which of the following Connection methods is automatically created by Ansys Mechanical when you import an assembly?
Consider the nodes lying in the middle of the pipe as shown in the image. Review the Directional Deformation in the X direction for System A (Contact), and select the best option below that is a correct statement.
For System B (Shared Topology), where does the maximum Equivalent Stress appear? Select the best option.
When using Shared Topology for this geometry, what was needed to be done in Discovery to ensure that nodes will be coincident when meshed in Mechanical? Select the best option.
For System A (Contact), which location has the maximum Total Deformation? Select the best option.
For System B (Shared Topology), add Force Reaction and review the total reaction force. What is the total Force Reaction in the Y direction? Select the best option below that is closest to the correct result.
