Here you will perform a preliminary structural analysis of the model using the explore stage in Ansys Discovery. The solution will be performed at two different levels of fidelity in order to explore the effects of changing the fidelity of the simulation. You will learn how to visualize and analyze the results. Also, you will understand the meaning of concepts such as stresses and factor of safety.
