0 of 10 Questions completed
Questions:
Quiz is loading...
0 of 10 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
Which of the following statements are true with respect to Hooke’s law in 3D space?
Which of the following statements are true with respect to transversely isotropic material?
Which of the following statements are true with regards to the Hooke's law?
Isotropic material is:
Which of the following materials are anisotropic? (Select all applicable)
Which of the following statement is true about the constitutive model?
Which of the following statement about Hooke's law is correct?
With Young's modulus and Poisson's ratio, which of the following parameter can we derive in a linear isotropic elastic constitutive model? (select all applicable)
Which of the following behavior is elastic?
With Poisson's ratio, one can determine:
