0 of 10 Questions completed
Questions:
Quiz is loading...
0 of 10 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
Which of the following connections may be used when the bolts are represented as solids?
Which of the following options gives the most accurate stresses in the vicinity of bolts?
Solids use _______________ connections while line bodies use ____________ connections.
When frictional contact is used between two bodies, which of the following is NOT true?
When threads on the bolt and the nut are not modeled geometrically, what type of contact may be used between the two?
Which of the following statements is true?
Which type of contact is used between the bolt head/nut and the mating components in case of a shear bolted joint?
Pick the correct arrangement of bolt representation methods which represents increasing order of accuracy.
Which of the following is NOT true with regards to modeling bolts as Beam Connection?
Bolts are modeled as Beam Connections when _____.
