0 of 9 Questions completed
Questions:
Quiz is loading...
0 of 9 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
Validation in CFD is a process to:
Which of the following is not a dimensional simplification for a flow model?
A conservative body force is a body force which can be described by:
Into which of the following category does the problem governed by Laplace equation fall under?
How are stream function contours related to velocity potential contours?
Identify which of the following is not a procedure for solving a potential flow model?
How can we construct potential flow solutions for flow around a circular cylinder of radius R?
Kutta-Joukowski theorem states that ________
What is the essence of modeling?
