Watch the following video for a demonstration of how to add a stent to the original artery geometry using Ansys SpaceClaim. You will need to suppress the solid created to generate the effect of the stent before opening the geometry in the mesher.
Quick Summary:
Create a new sketch, move to one end of the obstruction
Use Spline to mimic the artery boundary (just click on the edge of the artery that is visible and follow the dots that show up)
Use Offset Curve to create two more curves: one inside and one outside the artery
Return to 3D mode
Hide the artery
Delete the inner portions of the resulting surfaces leaving only the outer ring
Unhide the artery
Do the same on the other end of the obstruction
Hide the artery
Use Blend and then control + click the two faces that remain
Unhide the artery
Ctrl + Click the missing ellipse and fillet and click Fill if you haven’t already
