0 of 15 Questions completed
Questions:
Quiz is loading...
0 of 15 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
Which of the following statements is true about a white body?
Which of the following statements is true about radiation?
Which of the following statements is true about emissivity?
For the simulation of cake in an oven, which of the following statements is true?
The "Commands (APDL)" object in the simulation of the baking of a cake was used to remove the bulk temperature of the inner convection boundary condition. Pick the correct reason why this was performed:
For the bathroom heat lamp problem, why is the temperature of the area under the sink comparatively lower than the rest of the area of the floor?
