0 of 7 Questions completed
Questions:
Quiz is loading...
0 of 7 Questions answered correctly
Your time:
Time has elapsed
Earned Point(s): 0 of 0, (0)
Which of the following area is mechanics not applied?
In the simulation of the bike crank, what steps does an engineer need to do to build up the model? (Select all applicable)
Which of the following simulations can be done as a rigid-body analysis?
What would an engineer do when converting the helicopter pitch arm to a numerical model and conducting the simulation? (Select all applicable)
Select the correct statement/s about the helicopter pitch arm simulation
In the helicopter pitch arm simulation, why doesn't an engineer model the whole rotor? (Select all applicable)
Which of the following statements about rigid body analysis is/are true? (Select all applicable)
