Ansys Learning Forum Forums Discuss Simulation Fluids DPM problem with system coupling Reply To: DPM problem with system coupling
Luigi0
The second set of results refer to the second part of the analysis, when the piezo is on, so there is generation of acoustic waves in the fluid, and the trajectories of the particles should be deviated. I expect that particles move to the centre of the channel.nanalysis from 0 to 0.03s --> piezo is off, particles enter in the domain and the trajectories should be straight more or less.nanalysis from 0.03 to t-final --> piezo is on, generation of pressure waves in the fluid, particles trajectories should be deviated.nI should see trajectories deviations only when the piezo is on. Please let me know if I was clear. Thanksn
