Methods of Solving Problems in Structural Mechanics — Associate Certification
Current Status
Not Enrolled
Price
Closed
Get Started
This certification is currently closed
Ansys Associate Certification
🛈 Important Notice: This certification is no longer available for purchase. Check out our latest upgraded version here.
Description
If you have access through your organization, please click on the “Enroll” button to begin. Once enrolled, you will be presented with two sections under the Content area. Please click on either of the sections to start the exam.
You will have 30 days to finish both the sections. Upon completion of the certification exam with a passing score, you will be rewarded with access to a digital credential. If you do not pass on your first attempt, you will have one additional attempt within the 30-days from the time you purchased the certification exam.
Details
Certification Exam
Two attempts to pass within 30-days from your purchase.
Consists of 1 theory-based test and 3 simulation-based tests.
First certification test is 60 mins and is based on theory.
The 3 simulation-based tests, each being 20 mins, are based on Simulation setup.
Start anytime within 30 days and complete in one sitting once started.
Passing grade of 75% is required for all tests.
Software in the Cloud
Access free student software in the cloud for 20 hours.
Bypass the need to download and install software locally.
Designed to run on the free Ansys Student product.
Can use standard commercial or academic license of Ansys software.
Must use latest version of Ansys software. Confirm that you can set up, solve and post-process any model before starting.
Digital Badge
Highlight your successful completion of the Certificate.
Share digital credential with your social and professional network.
Digital credential is issued on successful completion.
Requires an account on the credential-issuing platform, Credly.
Credentials do not expire. No limit on the number of shares.
Recommended Courses
Ansys recommends the Ansys Innovation Learning Track titled “Methods of Solving Problems” available for FREE  here to prepare for the certification tests. This learning track comprises of following courses:
STRUCTURES
LEARN PHYSICS
Hyperelasticity
LEARN MORE
STRUCTURES
LEARN PHYSICS
Structural Instabilities
LEARN MORE
STRUCTURES
LEARN PHYSICS
Computational Considerations
LEARN MORE
STRUCTURES
LEARN PHYSICS
Mode Superposition Method
LEARN MORE
STRUCTURES
LEARN PHYSICS
Harmonic Analysis of Structures
LEARN MORE
STRUCTURES
LEARN PHYSICS
Time Integration
LEARN MORE
Completion of Certification Test
To enroll in this certification, please visit the Market space. Once enrolled, you will see the four sections under Certification Content below. Please click on “Theory Quiz” to start the exam. You will have 30 days to finish all the four sections and attempt to earn the certificate for the first time. Upon completion of the certification exam with a passing score, you will be rewarded with access to a digital badge. If you do not pass you will have one additional attempt to pass within 30 days from when you purchased the certification exam. By proceeding further, you acknowledge that you have read and understand the guidelines mentioned above and understand that this will be counted as one of the two allowed attempts.
Terms & Conditions
By beginning or accessing this Ansys certification exam, You confirm acceptance of the Certification Terms and Conditions and all program policies, if any, provided or otherwise made available to You, and You agree to be bound by the Certification Terms and Conditions.
Format of the Certification Exam
  • This certification exam consists of 1 theory-based quiz and 3 simulation-based quizzes. You will have two attempts to pass within 30-days from your purchase.
  • The first certification test is 1 hour (60 mins) in timed duration and is based on the lecture videos and handouts. This theory exam tests your comprehension of the subject material.
  • There are 3 additional tests, each being 20 mins long, that are to be taken after setting up, solving and post-processing Ansys simulation models. These simulation exams test your basic understanding of Ansys Mechanical for setting up and interpreting the results of structural models.
  • The certification test questions include single-answer and multiple-answer questions.
  • The test questions are based upon what you learned in the video lectures and handouts, and the completion of assigned simulation examples.
  • You will have 30 days to complete the entire certification exam process, allowing for sufficient time to download, set up and solve the simulation models before starting the timed portion of the certification tests.
  • You may start each test at your convenience (within the 30 days period), but once a test has started, you must complete it; there is no option to pause and come back later.
  • You will be provided with Ansys Workbench starting files and instructions for each of the simulation models.
  • A passing grade of 75% is required for each theory portion as well as the simulation portion (75% passing for all simulation models as a whole).
Simulation Test Requirements and Details
  • For the simulation test, the simulation models have been designed to run within the limits of the free Ansys Student product, found here. (Be sure to install Ansys Student software, not Ansys Discovery Student software.) Alternatively, you may use a standard commercial or academic license of Ansys Mechanical software if you already have access to one through school or work.
  • You must use the latest version of Ansys software. The Workbench project files will not open in older releases of Ansys software, so attempting to take the certification exam with older releases will not be possible.
  • The simulation models use Ansys Mechanical found inside of Ansys Workbench.
  • Before proceeding with the certification, you should confirm that you can set up, solve and post-process any model inside Ansys Mechanical, hence confirming your ability to run the software.
  • Starting the certification exam without access to Ansys Mechanical software will result in a failed certification exam.
  • As a guide, the actual setup and solving of the simulation exercise should not take longer than 2 hours per simulation, but you have 30 days to complete this along with the exam itself.
If you do not pass the certification test, you will be permitted to retry one additional time (i.e., 2 attempts in total) within 30 days from when you purchased the certification exam.
