Ansys 2024 R1: Ansys Sherlock and Ansys Mechanical Module and System Level Reliability
Overview
In this webinar, you will learn how the Sherlock-Workbench integration simplifies, accelerates, and expands mechanical, thermal, and reliability simulations of electronic systems. The content will cover how to:
  • Reduce the number of design iterations and physical tests that are required
  • Evaluate the reliability of electronic systems, including multiple PCBs, enclosures, fasteners, and other hardware
  • Export geometry and properties from Ansys Sherlock to Ansys Mechanical
  • Import simulation results from Ansys Mechanical back to Ansys Sherlock for life prediction calculations
Who Should Attend and Why
Reliability Engineers
Speakers
Kelly Morgan and Josh Akman
    0
    Your Backpack
    Your backpack is empty
