Optimize Your Simulation with Ansys Motor-CAD and Ansys optiSLang
<h2>About this Webinar</h2>
<p>
Electric motors are the best energy converters used in industry. The design process requires a complex approach that starts from specifications: electromechanical, thermal, and NVH. Considering all the multi-physics requirements of the electrical motor, it is paramount to make the right choices and reduce the cost of change throughout the development process.
</p>
<p>
Leveraging the performance trade-offs between multiple physics disciplines, including electromagnetics, thermal, structural, and the NVH, in a traction machine design is always challenging but critical. In this webinar session, we'll discuss how to govern the multi-physics design aspects of a realistic IPM traction motor during machine design optimization. This traction motor is designed for a modern, high-performance, battery-electric vehicle platform.
</p>
<p>
Ansys Motor-CAD and Ansys OptiSLang will be used to build an efficient design optimization workflow. The optimization approach will combine Motor-CAD multi-physics calculations with OptiSLang sensitivity analysis, meta-modeling, and optimization techniques to enable rapid trade-offs between competitive designs and find an optimum solution for a given specification in a computationally efficient way.
</p>
<h2>What You Will Learn</h2>
<ul>
<li>
Seamlessly set up a customized optimization problem in OptiSLang using the automated Motor-CAD integrated export tool
</li>
<li>
Quickly perform a multi-objective, multi-constraints electric motor design optimization using leading-edge multi-physics and sensitivity analyses
</li>
<li>
Trade-off multi-physics performance targets across an ample design space to comply with complete motor and system specification requirements
</li>
</ul>
<h2>Who Should Attend</h2>
<p>CAE/Simulation Engineers & Analysts in Electro-Magnetic / Electric / Motor Design in all industries + Academia</p>
<h2>Speaker</h2>
<p>Oleg Khromov, Senior Application Engineer at Ansys</p>
<p>Nicolas Rivière, Senior Application Engineer at Ansys</p>
    0
    Your Backpack
    Your backpack is empty
