Why getting incorrect contacts for a multibody part? Why some surfaces are missing? Using Creo Plug in mode for importing geometry into DM.
Tagged: 18, Cleanup/Connections, contacts, fluid-dynamics, General, Geometry cleanup, meshing
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document. Keywords: Creo, share topology
1. 2047053.pdf
- Skewness in ANSYS Meshing
