Licensing
Licensing
Tutorial:: Submitting Jobs to RSM from Workbench
    • SolutionSolution
      Participant
      This video shows you how to submit project updates, design point updates, and solution component updates to RSM from Workbench, and monitor RSM jobs from Workbench. Please refer to the attachment to access the Solution.
      1. v_wb_submit_rsm_UPDATED.mp4
; jQuery(".user-experience-select").select2({ data: data, minimumResultsForSearch: -1, escapeMarkup: function(markup) { return markup; }, templateResult: function(data) { return data.html; }, templateSelection: function(data) { return data.text; } , dropdownParent: jQuery(".user-exp-outer") }); jQuery(".user-experience-select").select2("val", "https://innovationspace.ansys.com/ais-experiences/"); var timesClicked = 0; jQuery(".user-exp-outer").click(function(e) { timesClicked++; e.preventDefault(); if (timesClicked%2==0) { //run second function jQuery(".user-experience-select").select2("close"); } else { //run first function jQuery(".user-experience-select").select2("open"); jQuery(".user-exp-outer").addClass("active"); e.stopPropagation() } }) jQuery(document).on("click", function(a) { if (jQuery(a.target).is(".user-exp-outer") === false) { jQuery(".user-exp-outer").removeClass("active"); jQuery(".user-experience-select").select2("close"); timesClicked = 0; } }); jQuery(".user-experience-select").on("select2:select", function (e) { if(e.params.data.ais=="true"){ window.open(e.params.data.id,"_self"); } else{ window.open(e.params.data.id); } }); });
