Is it possible to get the contact force and moment for a Bonded Contact Pair in Static or Modal Analysis ?
June 6, 2022 at 9:58 am
FAQ
ParticipantYes, it is possible to get the contact force and moment passed through a Bonded Contact Pair in Static or Modal Analysis.
1) Insert “Solution > Probes > Force or Moment Reactions”
2) Change the “Location Method = Contact Region”
3) Choose the appropriate Contact Pair and Evaluate the Results.
For this, Nodal Forces must be requested in the Output Under “Analysis Settings” before solving the model.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
