July 23, 2024 at 9:24 am
Watch & LearnParticipantIn this video, you will learn how you can visualize the Voxel mesh in Discovery Explore stage (2024R2 release onwards). This feature is currently available only for fluids simulation, with a prerequisite that a local fidelity is defined on any of the faces. The mesh can be visualized on outer surfaces as well as on a cut plan, and with contour plots if the surface display priority is set to outer or inner. This is also valid for CHT simulation, but not for structural or modal simulations.
