Licensing
Licensing
How to get rid of the error “Object reference not set to an instance of an object” when starting Workbench Meshing?
    • FAQFAQ
      Participant
      When trying to start ANSYS Meshing, the following error occurs: “Object reference not set to an instance of an object” This error can be fixed by renaming (or deleting) all version folders in the following location in AppData. C:Users’user name’appdataRoamingAnsys’version folder’ E. g.: If you have installed Ansys R 19.1, R 19.2 and R 2019 R1, delete the folders “v191”, “v192” and “v193”. Keywords: Workbench, Meshing, start-up error
