How can I select interior faces and other entities that are inside the model?
    • FAQFAQ
      Participant
      If the interior entity is on a separate body than the one above it, then you can hide the body that is in the way. Otherwise, the easiest way to select internal faces is to hover your mouse over the face, then press control on your keyboard while you scroll your mouse wheel. SpaceClaim will cycle through all entities that the mouse is currently over.
