General
General
[FreeFlow FAQs] How is SPH Adaptive Size different from standard SPH in Ansys FreeFlow?
    • FAQFAQ
      Participant
      In standard SPH simulations:
      • All SPH elements have the same size and spacing.
      • Resolution is fixed throughout the simulation.
      • Improving accuracy requires globally reducing SPH elements spacing.
      With SPH Adaptive Size:
      1. Element size can change locally during simulation.
      2. Resolution is higher only in selected regions or near boundaries.
      3. The overall number of elements can be significantly reduced compared to a uniform fine-resolution model.
      4. As a consequence of a lower number of SPH elements, the simulation execution time can be reduced.
      Ansys FreeFlow™ smoothed-particle hydrodynamics (SPH) simulation software
      Janaina Oliveira
      Technical/Product Publications
