Tagged: Analyze-FAQ, Ansys Discovery, electromagnetic, Explore-FAQ
September 26, 2022 at 10:15 am
FAQ
ParticipantDiscovery – Defining new material
Please follow below mentioned steps to define a new material:
1. Select the body and click the Hex icon to access Materials section. You can also click “Materials” button from the SImulation toolbar.
2. Select “Other” material option.
3. From the materials drop-down list, select “User Defined Solid” (or fluid, as applicable).
4. Once selected, the user defined material will get assigned to the selected body. Go to Physics tree and double click the user defined material to access and edit its material properties.
5. The edited User Defined Material will appear in the material drop down list as a separate material as shown below (notice the spanner icon located beside its name indicating that its material properties have been edited).
6. Once you define the new material, go to the Physics tree, then right click on the Material and select “Rename”. Y0u can now rename the material that you newly created.
7. On similar lines, you can also edit the properties of any existing material. The edited material will appear as a separate material in the list.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Structural Simulation using Bolt Idealization
- Ansys Discovery: Topology Optimization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery – Defining new material
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
- Ansys Discovery: Activating Beta Feature
