Tagged: Air, custom, filter, Granta, library, material library, materials, structural steel, water
November 2, 2022 at 9:17 am
Watch & Learn
ParticipantIn this video, we will see how you can change the default material in Discovery. You can select your material library and default solid and fluid materials in File menu > Settings > Physics, under Material Defaults. You must restart Discovery or create a new simulation for the new defaults to take effect.
- Discovery Downloads
- Ansys Discovery – Supported File Formats
- Importing an Autodesk Fusion 360 Design Study into Ansys Discovery
- Ansys Discovery: Customizing the Ribbon Tab
- Top New Features in Ansys Discovery 2025 R2
- Ansys Discovery: Creating Custom Shortcuts
- Ansys Discovery: Transient Simulation
- Change Language in Discovery
- Release Notes- Previous versions
- Discovery: Transfer to Mechanical
