Can’t select anything on Fluent Launcher except ‘X’ on the top right to close it but Fluent itself works fine.
April 13, 2023 at 7:32 am
Solution
ParticipantPlease refer to the attachments to access the Solution.
1. 2058348.pdf
- Q: How do I set the license server from my client machine?
