Can’t launch Workbench or AIM with error: Failed to load addin … Method not found: ‘Double Microsoft.Scripting.Utils.MathUtils.ToFloat64 …
August 25, 2023 at 12:16 pm
Solution
ParticipantPlease refer to the attachments to access the Solution.
1. 2052658.pdf
- Q: How do I set the license server from my client machine?
