June 6, 2022 at 10:54 am
Watch & LearnParticipantThis ANSYS How To video will demonstrate how to imprint geometry in ANSYS SpaceClaim. Imprinting enables you to mesh parts of a model individually, while accounting for connections to other bodies. ANSYS SpaceClaim Direct Modeler is the easiest and fastest solution to prepare geometry for simulation. SpaceClaim’s direct modeling solution speeds up time to analysis by removing the geometry bottleneck, and it shortens the time needed for analysis by allowing engineers to simplify models during pre-processing. SpaceClaim also provides a CAD neutral environment, freeing engineers to focus on the physics and modeling. SpaceClaim provides 3D modeling software to create, edit, and modify CAD or STL files for design, reverse engineering, simulation, manufacturing, 3D printing, and sheet metal.
- ANSYS DesignModeler: Imprinting Geometry
- ANSYS DesignModeler: How to Perform a Clean and Repair
- ANSYS Workbench CAD Interface for NX: How To Create Named Selections and Parameters
- How to perform a subtract Boolean operation in SpaceClaim Direct Modeler?
- ANSYS DesignModeler: Shared Toplogy
- ANSYS SpaceClaim: Shared Topology
- How to move component within the assembly?
- ANSYS DesignModeler: Weld Feature
- ANSYS SpaceClaim: Imprinting Geometry
- Bidirectional CAD Interface Between ANSYS Mechanical and Creo Parametric 2.0
