What kind of contact should I put here?
    • rajat
      What kind of contact should I put here? ANSYS
      I want to run a modal analysis on an assembly. The image attached is a simplified version of it. The "mount" attaches to the plate via bolts (red) and is threaded (blue) onto the mount. What kind of contact should I put at the interface (yellow).
    • Himanshu
      Modal analysis only supports the linear contacts. It this particular cases bonded contact seems to be good choice among all the linear contacts.
      • rajat
        Hello, Thank you.
        While doing other analysis like random vibration, quasi static, static structural, and thermal can I add a frictional contact (coeff: 0.2) between the two surfaces (SS 304 (bottom) to aluminum 6061 t6 (top mount)) and a beam element that connects the two components? Modelling bolt and adding pretention is expensive and it's affects need-not be studied in this case. We need to study only the behaviour of the mount and the plate under loads. Please help.
    • ashleytburnette
       It’s amazing how these choices affect overall performance!
      Edit by blocky blast a day ago
