TAGGED: cfd-udf-fleunt, dpm-udfs, drag-force, moment-calculation
July 18, 2024 at 3:00 pm
kiran.purushothamakeshavan
SubscriberHello,
I'm studying particle impinging a wall where the criteria for particle sticking to a wall is the moment (F*d) on each particle at the wall as a function of drag force and velocity of particle at contact.Â
I see that I can use DEFINE_DPM_BC for this.
Since I input a custom drag force model I would need DEFINE_DPM_DRAG, my question is about how I can import the drag force in this udf to my DEFINE_DPM_BC udf so I can calculate the moment on each particle at the wall.
Is there a way I can use both of these udfs under the same header and make it a whole different udf with multiple macros?
This whole criteria is for ansys to decide if the particles sticks or bounces off from the wall
Thanks,
Kiran
July 18, 2024 at 3:37 pm
Forum ModeratorWhat are you doing with DEFINE_DPM_BC to cause the particle to stick?
- The topic ‘Udfs for particle re-suspension’ is closed to new replies.
3597
1208
1092
1068
952
