Turbulent production term
    • thamilmani
      The Fluent postprocessed XYPlot files  for a 2D Line are all 0 for Production of k but the CFDPost results for the same 2D Line are finite.
      Any reason why this is happening?
      Where is the line?
    • thamilmani
      I am simulating a 2D axisymmetric heated pipe vertical flow of diameter 3mm and length of 0.2 m. The lines are made along the radial direction, at different axial positions, 0.06 m, 0.09 m, 0.18 m like that.
    • thamilmani
      I use the same lines for saving multiple variables, TKE, density, etc. Only Production of k has this issue. Even across the domain, when plotted contour, the Fluent shows 0 while CFD-Post shows finite values. I use k-omega SST model.
      Can you check planes in the domain? What does the velocity field look like?
Viewing 4 reply threads
