November 20, 2024 at 9:03 pmALEXANDRE COSTASubscriber
Can the experts tell how to access the TUI commands for the Fluent MPM model ? Unfortunatelly the documentation does not cover that detail.
Perusing the corresponding mpm addon.bin I found some variables, such as listed below :
(mpm-libname mpm-udf udf string-append mpm-create-mode?Â
quote boolean edit-inj-name ti-cmd-silent? ti-cmd silent? s? args cmd with-output-to-stringÂ
ti-menu-load-string format for-each var make-new-rpvar mpm? mpm-inj-data list mpm-use-bsp?Â
mpm-use-display-injection? mpm-display-out? mpm-use-soft-collision? mpm-injection-name stringÂ
mpm-inertial-momentum-factor real mpm-udm-offset integer mpm-use-markers-on-sphere?Â
mpm-max-number-of-points-on-sphere mpm-report-surface-area-ratio?Â
mpm-surface-area-option mpm-domain-extents real-list mpm-track-inter-contphase?Â
mpm-solve-temperature? mpm-orig-force-formulation? mpm-track-part-timesteps mpm-track-wt-fixvelÂ
mpm-track-zones integer-list mpm-drag-nodrag? mpm-drag-default? mpm-drag-morsi? mpm-drag-constant? ....et ceteraMy question is how to setup those variables.
Any expert advice is very very welcome.
Thanks.
1081
447
390
225
201
