The fl process could not be started.
    • rre285
      I was trying to run my UDF in Fluent 2023 R2 to do a meltflow simulation. The udf seems to be good, building and loading went good. the initialtization is okay, but whenever I run calculation, I resieve this error: "===================================================================================
      =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
      =   RANK 0 PID 22572 RUNNING AT a074478
      =   EXIT STATUS: -1 (ffffffff)
       The fl process could not be started."
      I am running in parallel mode. I am not sure what is the reason behind this failure.
      Can you run any models on that hardware configuration?
      • rre285
        Thank you for answering. Yes I've tried a simpler UDF and it was working fine, so I am not sure if the issue is with the parallel mode or with my complex udf.
      If a simple UDF works, it's likely your more complex UDF. Was anything more diagnostic printed before the node failures? The section you pasted is just a node kill message, and I'm expecting something just happened just before that.
    • rre285
      Nothing appeared before, there was a message that hyperid initialization is done then this error appears when I run calculation. So I have changed a little in the settings and this is the new error message that I recieved:
      job aborted:
      [ranks] message
      [0] process exited without calling finalize
      [1] terminated
      ---- error analysis -----
      [0] on A074478
      C:\PROGRA~1\ANSYSI~1\v232\fluent\fluent23.2.0\win64\3ddp_node\fl_mpi2320.exe ended prematurely and may have crashed. exit code 2
      No SIGSEV error or the like?
    • rre285
      yes, you're right. I just checked again and this is the full error message:
      iter  continuity   u-phase-1   u-phase-2   v-phase-1   v-phase-2   w-phase-1   w-phase-2   energy-p1   energy-p2           k       omega     time/iter
      Node 1: Process 24976: Received signal SIGSEGV.
      Node 0: Process 12484: Received signal SIGSEGV.
      =   RANK 1 PID 24976 RUNNING AT a074478
      OK, so look in the UDF to see what data is being called from Fluent: SIGSEV is often the UDF wants a value that Fluent doesn't know exists. Are you using any UDS or UDM?
    • rre285
      I am using UDMs. I think the issue was that I was using the wrong multiphase model compared to what I introduced in my udf. I ran through my udf again and now it is working.
      Thank you so much for your help.
Viewing 7 reply threads
