Electronics
Electronics
Surface Discharge Simulation result file in EMA3D
    • ssufi
      We have been running simulations for surface discharge in EMA3D with step size (internal time steps) of 5e-13s. However, as we increase the total time steps (number of internal time steps), the simulation time and the result file size increases. We tried using higher step size (larger than 5e-13s) but it gives incorrect result.
      1. Is there any way to reduce the result (.h5) file size by removing unnecessary data (it calculates about 30 different properties, we only use 3/4.)?
      2. Is there any way to extract the data only for a certain section of simulation (50000 to 100000 steps of a 100000 total steps simulation) from the .h5 result file?
      3. Is there any way to reduce the simulation time other than reducing mesh or total time steps?
      Thank you!
      Suaib
    • James Sherman
      This question would require a bit more taylored solution.  Please contact your professor to request additional product training for EMA3D.
      You can also get additional training tutorials from:
[bingo_chatbox] ; jQuery(".user-experience-select").select2({ data: data, minimumResultsForSearch: -1, escapeMarkup: function(markup) { return markup; }, templateResult: function(data) { return data.html; }, templateSelection: function(data) { return data.text; } , dropdownParent: jQuery(".user-exp-outer") }); jQuery(".user-experience-select").select2("val", "https://innovationspace.ansys.com/ais-experiences/"); var timesClicked = 0; jQuery(".user-exp-outer").click(function(e) { timesClicked++; e.preventDefault(); if (timesClicked%2==0) { //run second function jQuery(".user-experience-select").select2("close"); } else { //run first function jQuery(".user-experience-select").select2("open"); jQuery(".user-exp-outer").addClass("active"); e.stopPropagation() } }) jQuery(document).on("click", function(a) { if (jQuery(a.target).is(".user-exp-outer") === false) { jQuery(".user-exp-outer").removeClass("active"); jQuery(".user-experience-select").select2("close"); timesClicked = 0; } }); jQuery(".user-experience-select").on("select2:select", function (e) { if(e.params.data.ais=="true"){ window.open(e.params.data.id,"_self"); } else{ window.open(e.params.data.id); } }); });
