3D Design
3D Design
Structure tree names error
    • Roberto
      Good morning,
      I'm having a fairly serious problem importing a step from a client who uses SolidWorks, and it's not the first time this has happened.
      The step is made up of multiple components, and I see some of them with different names than the one the client gives me in his Excel sheet.
      I tried opening the same file with other software (I've attached a photo) and I see the correct codes.
      In this attached file, for example, I see the following components:
      "CA000464_CA000464-B" instead of "CA000464-C"
      "CA000597" instead of "CA000597-B"
      "CA000464_CA000464-B _1" instead of "CA000678"
      "CA000465_CA000465-B" instead of "CA000465-C"
      ETC...
      What could it be?
      SpaceClaim must open files with the same original name; it cannot change the name. This is a problem that needs to be fixed.
      I can attach the example file.
    • Tim Dukes
      Hi Roberto,
      I notice you are using 2025R2 I recently posted this - https://innovationspace.ansys.com/forum/forums/topic/spaceclaim-2025r2-step-file-export-issues/?template=discovery
      Have you tried with 2025R1 to see if there is any difference? Wonder if this is linked to the same issue.
    • Roberto
      Hi
      I also tried with the 2024r2 version and it's the same
      Regards
    • Roberto
      I'm waiting for a response from Ansys, can you tell me something please?
    • Devendra Badgujar
      Hi Roberto, Tim,
      I am working on this with the developers. I will update as I have more information soon.
      Devendra
Viewing 4 reply threads
