3D Design
3D Design
Script in SPCL to extract Beam Section Names of Beams
    • sorin.isac
      Hi All,
      I need to created a script in SpaceClaim to extract all the names of various beam sections associated to all beams created from a solid model by using 'Extract' command. Each correspondent section is placed in paranthesis afer beam creation (Extract).
      I have tried the help system but couldn't find any reference guide for SpaceClaim.
      Thank you for your help.
    • Atharv Joshi
      Hi Isac,
      Please try the below script. This should help you get names of the assigned beam profiles.
      You can append them to a list if needed.
      Regards
      Atharv
